Shaved Door Solenoid Problem
Discussion in 'Interior' started by Zach, Jul 22, 2004.
    Zach New Member
    A friend of mine recently bought a shaved door kit for his S10. It came with 45lb solenoids. Today we made an attempt to install them, but we ran into one small problem. Once we had everything hooked up the solenoids wouldn't pull the latch to open the door. He was told that 45lb solenoids would be more than enough. We tried everything from putting more tension in the wire, to giving it slack, and even switched the terminals as the manual told us. It still wouldn't pull the lever. Does anyone have an idea what the problem could be?
    corolla_man_j Guest
    Is the problem that the motor just isn't strong enough for the doors, or is it that the motor isn't firing at all?
    cleanrolla97dx Guest
    try lubing up all the pieces that go with the doorhandle / actuator then see if it works
    if not you might need a bigger solenoid
    Concordmk1 Guest
    There is no way in hell you need a bigger solenoid. My friend who had an S-10 bagged, shaved, supra tails grafted in the roll pan, etc. had 40 lb. solenoids.
    As stated, is the solenoid functioning at all? Because 45 should be more than sufficient.
    Zach New Member
    Yea its working fine, its like it just doesn't have the power to pull it. You can push the button to open the door and the solenoid pulls the cable tight then stops. I can put my finger on the solenoid and just put a little pressure on it and it opens the door. It comes VERY close to pulling the latch, but stops just short. I checked the length of the wire and it has the perfect amount of slack. I'll take everything apart toight and lube it up, and fill you in on my luck with that. Thanks for everyones input.
    Concordmk1 Guest
    Hmm, definately let us know. Does it have propper room to pull the cable as far as it needs?
    Zach New Member
    Problem Solved
    We installed the kit on the other door today and everything worked fine. Although it did take a couple tried on getting the tension set right for the cable. Once I got to looking at the other door that wouldn't work. I realized that there was a rubber bushing missing from the door pin. This caused the door to sag just enough so that it would jam when closed. I went to the local junk yard and got a bushing and now everything works perfect. Thanks for everyones input on this.
