Engine Seafoam help
Discussion in 'Powertrain' started by darkgamer1912, May 17, 2008.
    darkgamer1912 Member
    CT USA
    Seafoam help
    i picked up a can of seafoam the other day and ive been waiting to do it mainly becuase i dont know which line is the vacuum
    is it this one
    or this one
    any help would be nice becuase i cant understand the sticker on the hood
    JLee TD05 3SGTE
    NH
    Be careful. My engine went when I tried it. Most people have better luck with it than I did, though.
    Yeah, I wouldn't use it either.
    DeebsTundra Big Tires :)
    Near VoRtEx
    Something about sucking stuff through a vacuum line doesn't sit right with me.
    Use BG products. 44k and MI3000
    cgreen38 Common sense, p
    Baton Rouge, LA
    I used it at about 125xxx miles, and I"m up to 150xxx miles now. Just put it straight into the gas tank. That's what the bottle should say.
    CT USA
    ok maybe ill just put in in the gas then i was skeptical too about it i watched someone do it on a 03 matrix with 1zzfe and it worked nice but i was still very skeptical about doing it
    also how much should i put into the gas the whole thing or just some of it
    Baton Rouge, LA
    Read the can. It's a certain amount of ounces for each gallon, or something. Just read carefully and follow the instructions. It really works.
    JLee TD05 3SGTE
    NH
    The bottle has several options...in with the gas, in with the oil, or in through the carb/TB/vac line.
    Baton Rouge, LA
    Ok. I went through the gas tank (heard it was the best way to do it).
    CT USA
    im still skeptical on the vacuum i think ill stick with the gas
    also did it smoke when you put it into the gas and was it hard puttering when u tried to start it back up like ive seen this stuff do?
    Baton Rouge, LA
    Nope. No smoking that I can remember. Car has been running fine ever since (ran fine before, but I was told it's a good thing to use when you're at that much mileage).
    BG 44K owns Seafoam.
