Engine same engine different HP
Discussion in 'Powertrain' started by Bulletproofswordsman, Aug 3, 2005.
    Cape Coral, FLorida
    how is it that the 1zz in the corolla makes 130 but in the Mr2 and the Celica it makes 140?
    and the 2zz in the GTS makes 180, but the Xrs makes 170?
    is there some "secret" to getting that easy 10+ horsepower, or is there something really obvious that im missing
    Dr Tweak Mad Scientist
    Savannah, GA
    It's through the ECU tuning, basically the Celica and MR2 run the engine for performance and the Corolla runs it for economy. You can swap the Celica ECU in.
    Cape Coral, FLorida
    which would give me this secret 10 horsepower? so ill be losing some gas mileage
    UKO Jon
    Lawrence, KS
    Is it just that easy to swap ecu? If it is then I'm a retard lol
    Cape Coral, FLorida
    /\ same question
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    you cant be concerned with gas milage if you are looking for performance.
    Cape Coral, FLorida
    lol, right now i have the gas mileage of a hummer, trust me im not concerned, i just asked cuz of what tweak said about the reasoning behind the power difference in the cars
    Jersey City, NJ
    ur gettin 8 MPG out of a corolla. wtf did u do to it??
    JLee TD05 3SGTE
    NH
    The Celica also has a different intake manifold.
    Savannah, GA
    :laughcry:
    Swapping it is doable, but it doesn't just plug in. You'll have to rewire it.
    -Doc
    Cape Coral, FLorida
    aww fuck n/m then lol
    gota find sum1 who can do this
    the new corolla is heavy as fuk so toyota tuned the corolla ecu to have a higher torque band. Meanwhile Lotus tuned their ecu to run 190hp on the Elise.
    Jersey City, NJ
    you never know Tweak. people will do some crazy shit man hahaha
    Savannah, GA
    Been done a few times already actually :cool:
    Hey doc, can you make us some adaptor or something like that for our 1ZZ rolla using the Celica GT ECU? :p
    I heard that we can directly plug the auto Celica GT ECU to the auto 00-02 (dunno about 03), but will lose the reverse.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    u might just need reverse, lmao
    but, so if the lotus gets even more HP then why not just use the lotus ecu...
    teevee247 Well-Known Member
    Montreal, QC
    Because the Lotus uses the 2ZZ-GE, not the 1ZZ-FE :)
    Also concerning the 2ZZ-GE, if i'm not mistaken, the Lotus gets the higher hp number at the sacrifice of it's torque curve, which is fine in a car as light as the Elise, but in the Corolla and Celica that weigh about 400~500lbs more, you need the torque...
    killer2239 Lift at 5700rpm
    Lexington, KY
    The big talks for the 2zz are on 9thgencorolla.com under 2zz area. The loss is to gain some torque curve, however JCTurbo who is working on master tech for us XRS's, to lower lift to 5500rpm and tune the VVT to get more hp. JCTurbo also has a theory where the 10hp went to, but he is wanting to do more research to find out, so people dont f**k up their cars trying his theory.
    There is a 04 Matrix XRS with the camcom controller hooked up to tune VVT on the engine, with intake and exhaust he went from 174whp to 185whp with tuning the VVT.
    And for the 1zz, there is a different intake manifold, you can talk to Vamp about that, he has already done the switch to the celica on his car. And whoever mentioned the ECU swap change for years and stuff, as far as i know you are correct about that.
    xnevergiveinx New Member
    north royalton, oh
    lotus has some weak torque, but then again, it's super light, so it still moves like a go-cart on roids
    01rollas New Member
    the lotus sucks on on torque. it like driving a S200 with absolutely no torque literally. I test drove one on San Antonio and it sucks on launch. but after that it picks up lighting quick. I on the other hand am not concerned about power on mine since it makes enough already but with the additonal weight on it, it runs very slow. if i take all that off it runs like hell.but if i could get a different setup that would be great.
    JLee TD05 3SGTE
    NH
    It has a manual transmission and a clutch. Rev it..it'll launch.. :p
    01rollas New Member
    i did. I launched at 5K it peeled out and it still to a while to pick up untill i revved at 9K rpm.
    JLee TD05 3SGTE
    NH
    If the tires were spinning, all the power in the world wouldn't help.. ;)
    I imagine it's quite a kick in the pants when lift engages..?
    TRDxrs New Member
    seattle wa,
    Uhhh no it doesn't...different ECU.
    The lotus has 190 because ECU and headers coming off along with exhaust. More aggressive intake timing.
    01rollas New Member
    it peeled out for a very short time until the Stability, and Traction Control Systems Turned on i for got to turn them off. it caught on pretty quickly but the car has very low torque and high end HP but that is it.
    intake timing is slowed to 10 degrees lower than that of the regular 2zz engine. which is why it also has a higher oil pressure system ECU is very different and Lotus and Toyota have a setup that is no where near close to the other engines. and header wise they are not that much bigger in diameter but the design allows for more efficient flow.
    JLee TD05 3SGTE
    NH
    1) Yes it does. Re-read the thread -- we weren't talking about the Lotus when I posted that.
    2) There's no 's' in header.
    :p
    BLADDER_MASTER Active Member
    FL
    HeaderssssssssssSSSSSSSSSSSSssssssssssSSSSSSSSSSsssssssssSSSSSSSSS
    01rollas New Member
    header = 1 exhaust or opening to the exhaust port of an engine
    headers= Various number of openings to the ehxaust ports to the engine.
    FL
    If you n00bs can't figure out whether to say "header" or "headers", just say "exhaust manifold" and call it a day.
    01rollas New Member
    true, but i was just clarifying for them.hehe
