rotor opinions
Discussion in 'Stop, Drop & Roll' started by blue, Nov 22, 2004.
    blue New Member
    rotor opinions
    Does anybody have any experience or knowledge of these rotors from TriNET Motorsports. They have these on ebay (http://cgi.ebay.com/ebaymotors/ws/e...&category=33564) and was thinking of getting some. And aslo, they say that the zinc is electrically charged onto the rotor in chemical tanks (not spray painted on). Because you have the choice of making them black or gold. Does this mean that if I get them black (which I do, that's why I was considering to buy from them), the black zinc won't get scratched off after breaking?
    Not everybody at once now! Thanks.
    d_samurai Guest
    they may most likely warp on you in a few months.. i would go w/ the trusted brand name brembos-
    e_andree E
    MD
    Unless they are chamfered drilled, stay away from them. And any finish will just get worn off by the pads.
    Companies like this get the OEM blanks, and then just drill them themselves.
    CivicEater Guest
    rotora has awesome slotted rotors. i have no complaints from my set. 50K of heavy braking with no problems.
    CivicEater Guest
    oh, and.. the plating will wear off the rotor surface immediately. it will keep the rest of the rotor from rusting tho.. unless it's utter crap, which is a possibility
    get powerslots
    91DX Guest
    get endless. you cant go wrong with endless
    blue New Member
    Thanks for the tips, you guys helped alot.
