Engine Rod cap question
Discussion in 'Powertrain' started by AsianPersuAsian, Oct 9, 2004.
    AsianPersuAsian New Member
    Rod cap question
    Hey umm..I lost a nut to the rod cap bearing and i'm sorta in a hurry, i tried to get another nut but, the parts store said that they won't be able to get it in for a few weeks cuz of special order. Well what would happen if i put just the one nut on and torque it just a little over specs, would it last or what would happen?
    midniterains Guest
    the journal rides on the bearing, you NEED it, dont try to half ass this.
    CorollaULEV Guest
    Yeah - NOT a good idea AT ALL!!!
    You'll have a bearing cap and piston flying through the side of your block. Not to mention a system-wide drop in oil pressure. Bearing clearance is a huge deal when it comes to oil pressure.
    BAD BAD BAD idea!!!
    Trav
    Tokez420 Guest
    yup exactly what CorollaULEV said
    not to mention the fact that one must ponder how long this problem existed before you noticed it... better hope it wasnt too long or yur screwed.
