Road Noise Reduction
Discussion in 'Interior' started by ShinmaTsunami, Jun 4, 2004.
    ShinmaTsunami T-elos Rider
    Western NV
    I have a 97ce. I get quit a bit of road noise, so I was wondering how to go about lowering it. I'm looking into some softer shocks so my ride won't be so rough. I think that may be part of the problem, but not all.
    All advice, links and or suggestions would be greatly appreciated.
    CraigW New Member
    If you dont rotate the tires enough they will cup and cause noise. CW
    JaJae Guest
    sound deadening material will help like dynamat, fatmat, ect
    d_samurai Guest
    are these STOCK struts and springs were talkin about??? b/c if they are-thats the best ride comfort-it aint gonna get anybetter...LOWERING your ride will just make your life more of a living hell-imagine a knife stickin in your ass everytime you hit a bump..
    sean2sean Member
    so cal
    add about 100-200lbs of sound deadenin material... like dynamat extreme...
    i have about 100lb worth and it made a big difference... ill prob need another 50 lbs to do the room and floor panels...
    matadorCE Guest
    rough ride and noise have nothing to do with each other. the stock shocks are already soft enough. get better tires since that's where most of the noise comes from. btw, performance tires are loud so probably want a good all season tire with a quiet thread. there is a lot of info about tires on tirerack so look up what people have said and rated the tires for the ones that you're interested in.
    you can also put sound deadening stuff in the doors, trunk, and use the spray-on kind inside the wheel wells.
    Western NV
    Cool. Thanx guys. I'll look up the links and keep the advice in mind. I really appreciate the feedback.
