Engine resistor size for iar sensor
Discussion in 'Powertrain' started by jox_rolla, Jun 30, 2004.
    jox_rolla Guest
    anyone know the size of the resistor you put where that plug is on the 1zz-fe air sensor on the air box?????
    jox_rolla Guest
    *air sensor
    1zzRocker Guest
    try about 510 ohms.... or if you would like to experiment, plug in a potentiometer (variable resistor) and adjust the resistance. Heres a tip: Use an Air/Fuel display to calirate your mixture while you adjust.
