replacing dash cluster
Discussion in 'Interior' started by 03rolla59, Oct 1, 2003.
    03rolla59 Guest
    Just wondering how easy would it be to replace my gauge cluster and replace it with an s gauge cluster (i have a ce)?
    baller Guest
    Re: replacing dash cluster
    its acutally pretty easy.. get a S cluster.. unplug the wires in back.. and plug it in ur S cluster and screw everything back in. . PRolly take me 20-30 mins.. if u never took ur dash apart i'd say it take around 1 hr..
    03rolla59 Guest
    Thanks. Yeah, i just got an s cluster and i have a ce. I'm probably gonna put it this weekend. Thanks for the info.
    OC Rolla Guest
    Where did you buy yours from and for how much? I got quoted ~$200 for a new S gauge cluster from www.irontoad.com. Let me know because I'm probably gonna switch mine out.
    Oh, one more question... what color are the lights behind the S gauge? The CE is white lights behind a black background. I know the S has a white face gauges, but are the lights also white? If the white face is the only difference then im not going to get it.
    03rolla59 Guest
    I got it for $100 from a friend that works in an auto salvage yard. I dont know what color the lights are going to be but i'll let you know once i install it.
    OC Rolla Guest
    sweet, thanks man. 8)
    Patsfan123 Guest
    If its the same as my LE, then it should light up white.
    OC Rolla Guest
    For some reason I remember hearing that it lights up different. Both LE/S have white faces but S has red(?) lighting behind the numbers? But maybe not. If the lights are white then it's not worth it for me.
    Patsfan123 Guest
    I know on the S, the text is painted red/orange, while mine is green.
    imported_corollas Guest
    theres already our rollas in salvage yards?
    that makes me sad :(
    well anywho the gauges just light up white against the white face and the nupers dont glow they just painted red and u can just see the red cuz of the white light
    on my 04 S that is
