Removing Airbag Warning Decals
Discussion in 'Interior' started by tg518, Aug 26, 2003.
    tg518 Guest
    What is the best way to remove these annoying stickers from the visors without discoloring the vinyl on the visors?
    stinky Guest
    take them off the day you buy the car. Its actually the area around the sticker that will discolor. But thats only if you leave them on long enough.
    minja714 Guest
    goof off bro
    "goof off" yellow container in home depot, paint section. 3 bucks maybe for a small canister.
    tg518 Guest
    I will try goof off then.
    minja714,
    Which Orange County do you live in, CA or FL?
    SSJ_Rolla Guest
    Cali 8)
    tRav808 Guest
    blow dryer helped me take mine off... maybe goof off is better.
    ph0bi4 Guest
    tg518, did you have any problems removing them? I want to do mine, but if its too much trouble, i'll just leave them.
    tg518 Guest
    They are still on. The goof off appears like it might work but when I tested in on the corner of the visor the vinyl became puffy and removed the texture on the vinyl, so I would not recommend that approach. They also sell a water based goof off in an orange bottle, but that wasn’t strong enough. When I took a blow dryer to it that label seemed to get tacky and the warning label would come off in small pieces (very small pieces); it would have taken forever to take the labels off of each visor so I gave up.
