Rear suspension noise
Discussion in 'Stop, Drop & Roll' started by DJR, Oct 5, 2005.
    DJR Guest
    Hey guys I've got a problem with the rear suspension on a '95.
    Whenever I go over speed bumps in a straight line it won't do any noise but whenever I go over the bumps diaganolally so each wheel passes over at a time I may hear a "clunk" type of noise when each rear wheel passes over.
    My struts and mounts are about 3 months old. I got 17".
    Thanks for any advice!
    Silver Bullet New Member
    Your tires are probably rubbing. Examine the rear wheel well for rub evidence. Also look at the rear tires for cut or rub marks.
    ChristianVA New Member
    Did you do any suspension mods? check all your suspenison bolt to see if there tight. also try to notice any rubbing mark from the wheel.
    DJR Guest
    I swapped the 13" wheels to the rear to check if it was rubbing but the noise persists. It's more of a "clunking" noise rather than scrapping.
    I'm going to check also suspension arm bushings later on to see if I can get to the problem.
    THanks !
    97dx Guest
    check your upper struts nut
