REAL SIGNAL LIGHT.
Discussion in 'Exterior' started by special_ahs, Nov 11, 2003.
    special_ahs Guest
    REAL SIGNAL LIGHT.
    Do you know how make your real signal light to blink faster?
    By the way, is that a cooling thing to do?
    Toyo_Toy Guest
    I tried that before, it's pretty annoying. I think all you have to do is buy the bulb, and that's it.
    I'm not sure about "cooling", but some people actually finds it very "COOL" that their lights blinks 1000 times faster... :wink:
    Aloha!
    CorollaS916 Guest
    In my 94 camry i went into the "computer" part of the engine and was able to change the speed of it. You know where all the fuses and such are.
    bimmernut Guest
    that's usually the default indicator in most cars that the circuit isn't working properly - blinking faster.
    SSJ_Rolla Guest
    cut the ground wire that connects to the bulb (the middle wire) and u will have fast blinkers
    baller Guest
    i actualyl reconnected my front corner blinkers so it stays bright the whole time nad goes on and off when you blink. i used relays.. as a result my blinkers blink really fast too heh
    special_ahs Guest
    Do you see any future complication for doing this? Like blowing up your fuse box or burn out your harness..wiring?
    Blue_Diamond Guest
    what it is,
    you need to buy a bulb with a different handling wattage from the one on the car. To get the different speeds of flashing you need to get a bulb that has low wattage.
    It's "cool" in nyc but only if you get a super white bulb to give the car a BMW look.
