Rattling noise
Discussion in 'Care & Maintenance' started by eddy, Jul 18, 2007.
    eddy Well-Known Member
    Is it a rattle or a squeak? I have a minor squeak in my s belt and it disappears at high rpms, but is distinct when idleing.
    CountryBoyCanDo Guest
    Rattling noise
    I have a 01 corolla and when my car is running it makes a rattling noise. It does not get louder when u go faster but when your car is parked and running that noise will drive u mad. I have tightened up the exhaust clamp and put a new one on and i know it isnt that. Sounds like it is coming somewhere by the serpentine belt any clues?
    does it sound like metal hitting metal or plastic hitting plastic? do you feel any vibrations from the rattling or is it not that bad? Does the rattling increase in rattle speed as you accelerate? and (last question I swear) does the rattling ever stop during a specific speed or rpm?
    shubert_ae102 New Member
    de mountains :D
    my friends 7th gen does the same thing , and its his alternator . its a high pitched rattle kinda squeek isnt it? not like a squeeky belt , but almost like dry small bearings at high speed.
    Yeah it sounds like metal on metal, but i cant tell any increase in noise when i accelerate but when u sit at a traffic light and your music isnt turned up that noise is bad. It does not sound that high pitched however just clankin constant. I ask cuz i am sick of going to dealerships they always seem to find something new wrong that costs me money.
    de mountains :D
    have you checked your motor mounts ? does your engine rough idle?
    metal on metal huh? hmmmmmm.
    is it auto or manual?
    automatic and paying attention to it yesterday it only does that noise in drive when my foot is on the brake if i take my foot off and the car starts moving the noise is gone but when it is in park it makes the noise regardless
    de mountains :D
    could also be the torque converter showing signs of wear , how many mile on the car ? i would do like 94 said first , flush it and change the filter. then if it persist , have a mechanic check your motor and tranny mounts. if those are all good , i would start pricing a tourque converter. you could take it to aamco , the tranny specialist , theyll tell you excactly what it is.
    de mountains :D
    the in park reguard less sound more like something just rubbing together. which in turn , most like lt is severly worn motor mounts.
    supermann423 word.
    Los Angeles, California
    when im in reverse...my car sounds like its about to explode due to the rattling noise i hear...also i hear it very faintly around 900 rpm like once i tap on the gas pedal in drive...2001 toyota corolla LE with around 48000miles...
    94 rolla Guest
    possibly your linkage or your tranny. flush it out, change the fluid, and try it then.
    damn thats pretty low mileage. you should have a mechanic look at it if the noise is that bad.
    yeah i have 83000 miles on it and i have to replace the water pump so i will have my mechanic check out the mounts. dumb question but are torque converters expensive. I am sure u have to pull the tranny out and the cost is prolly labor but how much do the converts cost.
    de mountains :D
    yeah , after i read the "reguardless if park " its not the torque converter , good observation jtweezy , water pump would be a good candadite , does it make the noise when its cold?
    also is this the first thing thats ever gone wrong w/ the car?
    jtweezy New Member
    Irving, TX
    it cant be your Torque converter.. sounds more like your water pump is about to blow.... samething happened to me...
    Legit01Rolla Active Member
    i think im having the same problem...damn
    yeah it does it regardless of the temp but my water pump was just replaced too
    dammit mine just started making this sound!
    lol dammit wheres the holy thread revival pic?!
    nice red x lol
    yes but they are not trying to get their post count up.
    The "insert/edit image" button never works anymore. its ridiculous it works for like the first view then i come back and some smart ass douche bag has a "nice red x" comment.
    What are you talking about CorollaGT who said anything about post count, failure.
    this ^^^^^^^^^^^^^^
    Nice red x, epic fail.
    noobs ^^^^
