Engine radiator fluid
Discussion in 'Powertrain' started by polo708, Jul 21, 2004.
    polo708 New Member
    9thgencorolla.com
    radiator fluid
    What color is our radiator fluid? Does anyone know... orange, gree, blue, etc... thanks.
    oxymoron Guest
    Should be red. If it was built in Japan it may be pink.
    Addicted2Boost Guest
    Mines was pinkish red. Built at Nummi though
    GT-R Guest
    Sorry to be a bit off topic but what are some other differences between the japan built and canada built corolla? I thought they were all built in canada?
    polo708 New Member
    9thgencorolla.com
    Mine was built in Michigan... :?
    lonelydriver New Member
    i thought they only built corolla's in california, ontario and japan
    APC_MATRIX_ Guest
    We have Red fluid :wink:
    CorollaAltis New Member
    i dont know about the canada but the US and Japan corolla difference is that the silver corolla has a different shade. the japanese has more of a green tint to it...kinda lighter shade than the US one. i dont know about hte other colors though
    half way through 03 they changed to red coolant rather than green. There is a TSB about it
    whats the difference? and those fluids toyota sell are red too right? cuz im planning to flush it and add redling water wetter to see if that thing really works
    APC_MATRIX_ Guest
    It visibly lowers the operating temp, I have some in my car and I can't even make my car get hot.
    CorollaULEV Guest
    how much water wetter do you guys use? I've always mixed the anti-freeze/water @ a 50% mixture. Is that still true, then just add a bottle of water wetter to it?
    Thanks,
    Trav
    APC_MATRIX_ Guest
    That would work fine. Watter Wetter works better with more water in the mixture but then you obviously aren't as protected against freezing and crap. I wouldn't go lower than 25% antifreeze :wink:
    RollaS New Member
    it's actually from red to pink.........i've seen the TSB. Also I have one of the very first 03's and it came w/ red.
    polo708 New Member
    9thgencorolla.com
    is it going to make a difference with the supercharger installed?
    APC_MATRIX_ Guest
    Considering it should have came with a lower thermostat (a new one, not sure if it's lower or higher actually), it should still make a difference. If the new thermostat is lower, it won't make as big a difference though.
