question
Discussion in 'Stop, Drop & Roll' started by DrunkSaru, Feb 12, 2007.
    slicks? uh.. if he wants to do burnouts, slicks will not work. They will grip and make his car go zoom. hahaha.
    If he wants to spin the tires so bad it's really simple. Tell him to go to the local pick a part and buy 2 mini spare wheels with tires. Those little things will spin like crazy if they're the drive wheels. hahaha
    corolla_kid88 Guest
    question
    my friend dean has been doin burn outs for a lil over a year and fucked up his auto tranny twice. he doesnt do n-bombs but he put it in reverse and half gasses it and the floors it into drive. can someone write the write way to burnout so i can tell him please. thanks.
    cgreen38 Common sense, p
    Baton Rouge, LA
    There is no "good" or "right" way to do a burn out. There's also no reason to do it. If you insist on it, get a manual tranny, keep it in gear with the clutch down, then dump the clutch.
    corolla_kid88 Guest
    o i know that abt the dumping the clutch, done it many civics. but he has a auto. is there a way to do it with a auto?
    MattAveli Modifier
    Cold Ass Canada
    auto's arn't designed to do a burn out, if he keeps wanting to do them he'll always have tranny problems. my only solutions for this is to get a manual tranny or slap a turbo kit on it the added power should make the tires squeel even with an auto tranny, he's not very swift kicking it from reverse to drive, what a way to break the teeth off the gears. i wouldn't recommend the n bombs either that's even worse than what he's doing to reverse.
    you do burouts on an auto, say bye bye to your tranny in about a year. your first gear will be F*cked
    The only semi-safe way is to do it naturally. Have the front wheels in a dip or in water or both, pull up the ebrake and floor it. Or if you have enough power, just do it off a stop. Why would someone want to do a burnout anyways? It ruins the wear on the tires and reduces the life of the engine and every other moving part that has to endure it. I'd rather burn rubber carving the canyons.
    corolla_kid88 Guest
    i no hes a dumb@$$. but he replaced his tranny twice and he was tellin me me wanted to get slicks for it. i told him just get old tires and do it but hey he wants 2 f*** up his car let um. i cant tell him not to.
    Hmmm I always wanted to do that myself... just not in my own car. LOL
    corolla_kid88 Guest
    ill tell him when i talk to him today. i be sure to tell tell him hes a dumb@$$ again. hhaa
    corolla_kid88 Guest
    here 2. hw did it today and used laundry detergent. he didnt do to bad.
