Engine question for people with high CR
Discussion in 'Powertrain' started by Ninety Four, Jun 29, 2004.
    The kind from Iraq.
    CraigW New Member
    On my stock 00 Corolla in the warm weather I MUST run 91 or higher to keep the engine from spiking under load. CW
    w1ngzer0 Guest
    CivicEater Guest
    i use the kind with octane
    w1ngzer0 Guest
    what gas are you running?
    corolla_man_j Guest
    what is high CR?
    XS PSI New Member
    cuchie rationing
    burbod01 New Member
    come on PSI
    its cuchie rating
    XS PSI New Member
    oh damn...sorry. My bad. U know me and dem technical terms.
    burbod01 New Member
    life would be wonderful if we could all be "running" a coochie rating of 90 or higher
    blancokracker Guest
    not really....think about the std's
    burbod01 New Member
    std's lower the coochie rating silly...
    rolla02 Corollalcholic
    Delaware
    I'm running on 89 cause my car oppps I mean my bitch of a car does not want to run right on 87 and nothing the I have done to see about fixing the prob is working.
    d_samurai Guest
    curious, how do you tell if your car doesnt "enjoy" 87 or the "regular"
    Delaware
    the way she runs.
    87 really really really really shitty
    89 runs good
    XS PSI New Member
    kewl but I heard on this other board that 87 has half the calories of 89. So now u can enjoy more of the 87 without the repercussions.
    Delaware
    This thread is fucking hilarious
    AlaricD Guest
    I just use 87 octane (using FTC (MON+RON)/2 method), which is what my manual specifies. (It also states that for locales that do not use the FTC method of octane calculation, it must be 91 RON.)
    In high altitudes, I use 85 FTC octane fuel. Higher octane than that and the car has very little power and I have to creep up the hills along with the semis while the people that got the right gas zip on by....
    For those confused on RON (Research Octane Number), MON (Motor Octane Number) and the FTC method of calculating octane, go here:
    http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
    Also, be sure that your compression ratio is the same as your coochie rating...
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    im more curious about the question than the octane rating - unless you have a corolla XRS, or have swapped engines or pistons - then we all have the same CR - 10:1 on the 1zz-fe and im not sure about the pre-98s but im sure they're similar
    thespud: CR is short for compression ratio
    w1ngzer0: Have you changed pistons or other internals? If you have, I would just experiement to see what's best for your particular car. If you only have bolt-on mods, like I/H/E, then changing to a higher octane fuel probably will hurt performance instead of improving it.
    Kaizen Guest
    My Car is on the atkin's diet...
    thespud Guest
    Meanwhile, im just confused... in Oz i dont think i have ever heard of CR.. but in responce to the question.. i use 98RON, which is as high as we get in Australia unless we can get AvGas which is 100RON.
    I only use 98 coz the 20v demands 100RON.. but the 16v (4A-FE) only needed 92RON
    Delaware
    UMMMM wingerz0 was banned, for some odd reason
    turbo4age Love to Hate me
    NV
    i use 87, it runs fine with my timing and current CR all the way to 7800 with no missing
    thespud Guest
    fair enough... u had me all confused for a minute there...
    Mike4831 C-Town Pimp
    Statesboro, GA
    it really depends. if i am running errands for the family and they let me fill up i get 93 ir i am paying for it i get 87. the may be a slight difference but it isn't that noticible.
    I see a definite drop in MPG, but I guess not as much with performance. I usually get about 260 miles or so out of a tank before the light comes on and the one time I filled up with 93, I swear it seemed like I barely got 200 miles out of a tank. It was a dramatic difference.
    toyotaspeed90 New Member
    Bellingham, WA
    the mr2 gets 87 octane.... (bigport 5 rib low comp block).... the ae92 gets 91 octane (smallport 7 rib high comp block)
