Engine question about injectors
Discussion in 'Powertrain' started by hooolala, May 14, 2004.
    hooolala Guest
    i'm thinking about upgrading my fuel injectors to match my TRD SC, so my question is what kind of fuel injectors can i use? can i use the one from 2ZZ-GE? or is there a better one?
    TurboRolla21 Guest
    I need to know also...What injectors can I fit (if any, with no problem) in my 1zz-fe???
    I really need some...I know the old rolla injectors wont work nor Solora or Camry. What will, without any modification or custom made--Something I dont have the $$$ for. Thanks
    well i dont know the injectors flow rate or duty cycle for the ZZ series engine but why do you need to upgrade your injectors to "match" your SC? TRD designed the SC to be a self contained bolt on unit and also included a 5th injector.. just dont make sense for me..
    hooolala Guest
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    Wish I could help you man lol but I have no clue I'll ask my friend and see if he knows....he's like an expert on everythin lol
    toyotaspeed90 New Member
    Bellingham, WA
    find a page that lists the nippon/denso/bosch injectors... look under your hood & find the color... match it to what's on the list... find out if they're high or low ohm... then go from there....
    BLADDER_MASTER Active Member
    FL
    That's helpful. I should check out the same for the heck of it.
    heh - ya know its funny...
    dropping 450cc injectors and a 3bar map sensor in (pre 00) you can do it w/o any tuning. (i know i've tested this theory) I'm running 550's and using minor mod in the compensation with my eManage along with the 3bar.
    FL
    I'm guessing he wants to upgrade the injectors for when he starts to increase power out of the S/C, he has the adequate fuel for the power.
    TCS-Mike Guest
    Convert to carbs dude !......
    hooolala Guest
    550cc??
    where did you get that?
    RC Eng.
    forget that.. where'd you get the 3bar map sensor? Sounds better and more cost effective than using a missing link..
    umm.. i guess if it worked for you.. Well theres 1 more reason to go with the EManage over the Apexi unit..
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    RC Engineering won't fit. I talked to them over the phone. You can get Power Enterprise injectors though.
    XS PSI New Member
    I heard that s2000 injectors will work but I'm not too sure...
    Derrick you are correct.... guy I bought them from originally said RC Eng (somehow that stuck in my head) but they are Power Enterprise... Sorry, I stand corrected... :)
    heh, not that I'd suggest this to anyone... but I used the signal from my Greddy 3-bar that came with my eManage.... *listen as scary music plays*
    *shrug* it works...
    The Apexi unit is a good - but only if you're wanting to tune your MAP/MAF voltage signals and some other monitoring capabilities. It is nice to be able to tune your injector duty cycles and tweak the ignition curve as well however. And don't get me wrong - the eManage is a bit quirky until its all setup right, but once it is - sooo nice...
    so how'd you finally got it right? trail and error or did you have to pay a shop to dyno tune?
    some of it was trial and error - but there wasnt that much error.
    1 thing however, when tuning a boosted car for fuel.... **USE A WIDE-BAND O2 METER** ;)
    That thing is your friend... keep it holding right at 11.5 to 12.0 and you are golden. Then you can do some other minor tweaking to ignition, etc... dyno + wideband is always the best combo however.
    blancokracker Guest
    a shop should have the wideband and o2 meter themselves.
    o2 meter? do you mean AF Ratio? Those gets espensive don't they?
    Rosedale, MD
    I got a wideband O2 in my dash so I can street tune my car once the turbo is in. I got it for $325 online.
    the AF is a wideband and requirs a wideband O2 - guess I should specify ya need both components... :)
    Yur my hero...
    Bellingham, WA
    unless it's AFM based.. (ie, all 4a-ge and older sport corolla's).... you can't use much larger injectors before it gets unhappy.... when i turbo my aw11 (once i actually get it) i'm gonna have to use the cold start injector for extra fuel until i setup the car with a megasquirt
