Question about HID kit
Discussion in 'Care & Maintenance' started by KrypticKarma, Dec 28, 2009.
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Hey guys just have a question. On my honda accord I have a set of HIDs (4300K) and the passenger one is turning red after warming up. Have you guys ever experienced this? its quite noticeable while driving and I bet everyone else on the road can tell too. I can take some pictures if needed. I just wanna know if anyone here experienced this and what the cause could be.
    Thanks.
    Robbie
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    Sounds like a bad bulb to me....
    EliteRolla Well-Known Member
    Mesa AZ
    93 Rolla, 96 4Runner
    that sounds bad ass you should get another bad bulb for the driver ha ha ha
    Could be a bad bulb or a bad ballast not supplying enough power to drive the bulb. Swap bulb positions and see if it turns red. If it does, bad ballast. If not, bad bulb.
    what he said.^
    Also check all the wiring make sure nothing is not connect. One of my wires came lose and it was causing the whole bulb to not work. I SUPERGLUED IT BACK:)
    Oshkosh WI
    Thanks for the input guys. My accord does have flip up headlights so maybe something got pulled loose. Ill definately try switching bulbs around when we get a day where its above 15 degrees haha. I did a little searching on other forums and some other people said they turn red right before they burn out. Hopefully warranty will cover it.
    Even if it isn't covered, 35W HID bulbs are only 20 bucks for a pair. 50/55W are 30 bucks.
    Oshkosh WI
    Yeah ill probably end up buying new bulbs. The HID kit i got from ebay and it shipped from China, so ill just keep the good bulb as a spare.
    Make sure it isn't a bad ballast first or else you'll waste money on bulbs.
    Oshkosh WI
    yeah. another cooolld night. on the way home from the mall my buddys blazer said 11 degrees out. I can wait to check them :)
    nyrican52884 Active Member
    Plymouth, MA
    Also check your ground wires.
    x2
