Engine Quaife Differential
Discussion in 'Powertrain' started by Bolt, Feb 2, 2004.
    Bolt Guest
    Quaife Differential
    Has anyone here installed the Quaife limited slip differential? I'd like to know how much difference it makes with the handling of the car.
    From it's website http://www.quaifeamerica.com/differentials/diffs.htm it seems like it'll improve handling, stop wheel spin, help a lot on snow/ice and in rain, and it comes with a lifetime warranty. It also doesn't have clutches that'll wear out and doesn't need special oil. Only problem is that it's $1800 with installation.
    Is it worth that price? It's so easy to spin the wheels with the Corolla in first and second gear. Every time I hit a bump or pass over a sewer grate the wheel will spin. I can't understand why all cars don't have an option for something like the quaife.
    Tro1086 Guest
    I think it would deffinately help improve traction and therefore help with acceleration. It would probably improve traction on the snow alot too. I would get one right now if I had the money.
    Dont know if you have seen this site yet, but you might check them out for toyota parts, they also carry the quaife diff. too. http://monkeywrenchracing.com/toyota.html
    I have also seen a TRD diff. out for our cars, i think it was only $700 or something at vpower.net.
    I dont know if its as good as the quaife diff thou. I think i would go with the quaife because it might be better quality. But thats mostly my opinion
