Pros and Cons of lighter rims
Discussion in 'Stop, Drop & Roll' started by wasabinuts2go, Nov 20, 2007.
    wasabinuts2go BeeP BEEP!
    Norcal
    So yea a lot of people say lighter rims are better.... but i really don't understand how to answer this question since there is really no right or wrong answer. What do you guys think?
    lighter is better but also depends on what type of material it is made of and how it was made. lighter could also mean very weak
    If you want light and strong then you'll want forged and lightweight. You might get away with a lightweight cast rim. I haven't had any issues with mine.
    i would get em but the offset says i would rub...
    Same here, I haven't have any issue with mine.
    Both rollatuner110 and I have Konig Heliums, they're 10.8lbs a piece.
    haha I do rub. But that problem is mostly gone when I rolled my fenders. Getting a stiffer rear suspension will completely eliminate it.
    they'll still rub when the springs compresses, just dail in a little negative camber.
