Engine Powerdyne Superchargers
Discussion in 'Powertrain' started by Barnacules, Sep 17, 2005.
    Barnacules 100101101011011
    Duvall, WA
    I contacted Powerdyne about a possible application for Corolla's and I'm waiting for them to get back to me. The idea of turbo is awesome but I want something that is a little easier to install. And these powerdyne superchargers basically replace your A/C compressor in the same bracket and pull its power from your cars belt drive. And that is it. No messing with manifolds, downpipes, etc, etc. Plus they make 6 - 15 psi boost based on the pully size and they require no oil lines for cooling. You can even use an intercooler so I'm thinking that I may pioneer this if they get back to me and just buy one of the chargers and fabricate the bracket for it and tie it right into my engine. Then I'll get a fuel management setup so I don't blow my motor up. I think a supercharged 1zz-fe would be kind of cool since it would help it make power in the low end. Anyways what do you guys think?
    Dr Tweak Mad Scientist
    Savannah, GA
    For the money involved, you could have a *nice* turbo setup. And you have to give up your a/c. But other than that, they're really cool! :D
    jtweezy New Member
    Irving, TX
    I've talked to them before....you could have just asked me....the cost of there kit is 3000.00 thats the import kit....then you have to get somebody to make the custom bracket and intercooler...i believe...something like that....and yeah those sound bad ass....they sent me info and charts of the different types of chargers they have and the best 1 they have is the oil less setup....man i have a turbo setup but hey they sell you mostly everything you need and if they were to just draw up designs of how the bracket should be made you could have somebody make it for you......but let me know what you decide on....
    Duvall, WA
    Actually I was just going to buy the head unit (500 - 600) on ebay and fabricate the rest of the setup myself. I have access to raw metal, cutter, welder and bender so I could totally make my own bracket with little trouble. What else would I really need other then fuel management and a blowoff valve?
    jtweezy New Member
    Irving, TX
    belt....intercooler, piping...thats it ....get the oil less supercharger...i know a place here in texas who sells them for 600
    Duvall, WA
    Dude, if you could give me the name of one of the places selling the units for $600 I may have to throw down and buy one. The major appeal is ofcourse is that the install wouldn't be nearly as complex as a turbo since all I would have to fab is a bracket and piping.
    jtweezy New Member
    Irving, TX
    look up www.superchargerrebuilds.com they are here in waxahachie texas ask for the oil less supercharger....and last time i talked to them they said they would also throw in a plate so you can make it into a bracket for free.....what year is your car? maybe i could take my 98 rolla so they could see what kind of design you would need....well check them out...
    01rollas New Member
    i'd rather have teh power steering out instead of my A/C but something like that does sound pretty neat. but i agree with Dr. T and just stay with a turbo.
    jtweezy New Member
    Irving, TX
    man who told you you had to stop using your a/c????thats a lie!!!!
    01rollas New Member
    i was going by the first post. if i could get a supercharger in my 01 i would definatley go for it but nothing is going to get installed till i get back or more so even later. right no i am no longer driving my car and it sits in the garage with only 55K miles.I have it sitting on blocks and with fluid stabilizers. but if i had the choice of a turbo or a supercharger without having to remove my ac or pw i will go for it but if not i'd go for the turbo.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    you wouldn't like to drive a corolla without power sterring :-/ the steering wheel is like turning a pig
    Duvall, WA
    It is a 2001 Corolla. That would rule if you could see what kind of design would be needed. Let me know if you find anything out. Turbo is totally badass but I'm thinking starting from dead scratch the powerdyne supercharger would actually be easier but I need to do a bit more research.
    Yeah I agree, I really don't want to loose power steering or A/C. But I think with a longer supentine belt the super charger could fit in there on its own with a modified bracket.
    01rollas New Member
    if there is any way they could put it in the back would be good only the heat from the header manifold is the only problem i think unless heat shield it added or put on.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    I know when I turbo my car I'm loosing the A/C for sure I haven't even used my A/C once since I own the car... so kinda pointless to have it
    01rollas New Member
    is your area. down here it averages about 105 to 110 daily.
    Littleton, CO.
    eh it's Colorado dude, I even drive with my window open 365 plus with these gas prices can't use A/C it'll drain my gas lol
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I actually get less mileage with the windows down... air drag...
    01rollas New Member
    yeah but the A/C puts a strain on the engine as well.
    Littleton, CO.
    eh well all I know is that well A/C is of no use to me really
    01rollas New Member
    ..... and i have to recharge mine about once a year and i added another fan to keep it even colder!
    Littleton, CO.
    I just don't like A/C plus I need to drive at least with a little bit of my window open, I feel all caged when I close all my windows lol, I need to hear the outside :p
