Power Door Locks
Discussion in 'Interior' started by TheOne, Jul 12, 2005.
    TheOne Guest
    i have done it many times. i used to be an installer. as far as cost. i wouold say about 9-20 dollers per door, depending on were you get your parts. and then add 2 relays and a monetary switch cost for thoes items should be under 10.00, or you can just use the alarm to lock/unlock. so your total cost for a 2door if you do the labor should be somewere around 30-50 max. as far as deficaulty i would say if you can install an alarm. you should be ok. as long as you know how to do revers polarity door locks. please feel free to ask me ? if you need more help:)
    supaloop Guest
    Power Door Locks
    Has anyone here ever converted your powered by yourself door locks to power door locks? If so, how is it done, what's the cost, and how is the install job like?
    I definitely don't know how to install an alarm... I see kits online starting around $75-$100. If I took it to someone to install for me, I'd probably pay at least $150. I work from 8am until 7 some days, so, even if I knew how, there's no way in hell I could install it myself.
    TheOne Guest
    i see your problem. i guess if i had to pay to have them installed by someone a good price for 2 doors with parts and labor would be about 100.00 a very good deal would be 75-80
    and a bad/high price deal would be anything close to 150-180. hope this helps.
    KainAzeroth Guest
    Thanks
    I was just about to ask the same question. I have a 2005 corolla CE and my idea was to go to one of the local car junk shops and just take the automatic locks and wires and switches, etc. from an LE or S model. Sound like a decent plan?
    jayjay_rolla95 Guest
    i got a 95 corolla and i converted my manual lock to power locks... took me at least 3 hours, which i think could have been faster if i have all the tools that i need... had no previous experience with anything like that but was able to do it, which means it is easy, just time consuming... cost? $45...
    supaloop Guest
    what kind of conversion kit did u get???
    i think its Bulldog Power door lock kit...
    caribbean custom designs Guest
    Hey I want to convert my girlfriend corolla 2005 to power look how do I need to buy and how do you make it. Do you have pictures? Thanks
    krazykanuk New Member
    hi
    i got the power locks, the actuators and such.. i'm installing an alarm soon, but would like the actual power locks physically mounted in the doors.. and am looking for some guidance on how to do this.
    any help would be greatly appreciated...
    maybe some direction adn pics if possible
    juniorn2 Guest
    yo i went 2 places to get door lock put on my 04 corolla ce and they was like it cant be done i was tight they said something about the door didnt have enough clearance but if any 1 did this to a corolla my year let me know what kit you got cuz im dying for power door locks
