Engine port and polish
Discussion in 'Powertrain' started by HK-Racer, Jun 24, 2004.
    HK-Racer Guest
    port and polish
    how does you port and polish? i dont understand how that works.
    COROLLA1ZZ New Member
    HK-Racer Guest
    oh i see. so what do i use to grind some of it out?
    here's what a friend of mine did...he took home a motor in pieces from a junkyard, and did all the work on a separate motor...so if he messed up, he'd have his original motor intact.
    try that instead of doing this to your current motor.
    HK-Racer Guest
    yeah that would be safe to do.
    indeed. he's also overboring the TB himself, doing higher comp pistons...etc. it's just safer on another motor so you still have yours intact.
    HK-Racer Guest
    yeah i think ill have to do that first. just incase i mess up. well thanks for the tip.
    np...good luck with it :)
    HK-Racer Guest
