Pioneer "Q-Factor"
Discussion in 'Interior' started by akchurchill, May 14, 2004.
    akchurchill Guest
    Pioneer "Q-Factor"
    Is anybody familiar with the Q-factor on pioneer decks? I know it adjusts the eq but i can't figure out the frequencies or what sounds best. Any help?
    bimmernut Guest
    I thought "Q" factor had something to do with subwoofers and their enclosures.
    oxymoron Guest
    Q factor applies to any electrical or mechanical system that has a resonant frequency. Q is a measure of how steep the resonant curve is. For an equalizer, a high Q means that only a small band around the selected frequency is going to be boosted or cut. The lower the Q, the wider the frequency band affected. For a speaker, the impedance rises sharply at the resonant frequency. Q is a measure of how quickly the impedance rises (before resonance) and falls (above resonance) with frequency.
    Unless you have access to a good spectrum analyzer, the best Q is the one that sounds best to you. It's generally not very useful in a car though, unless you have multiple bands to play with.
