Pigeon Toed 97
Discussion in 'Stop, Drop & Roll' started by sxlostv1, 2005年11月05日.
    sxlostv1 New Member
    Los Angeles
    get your allignment checked. if anything, id say replace your struts. they could be blown.
    skylin5_2 Guest
    Pigeon Toed 97
    My Corolla Is Sitting What I Call Pigeon Toe, Body Sits Low To Tires(no Lowering Springs), Tires Wear Unevenly. I'ved Been To Goodyear, Firestone And A Local Suspension Shop.
    Goodyear- Your Suspension Is Fine
    Firestone- Same As Above
    Local Suspension Shop- Bent Struts, And Strut Mounts
    Is It Possible To Bend The Mounts (what Would Be The Flaw There)
    CorollaULEV Guest
    Do you mean that the FRONT of the tires are pointed inward toward the nose of the car?
    If so, that is either a BADLY needed alignment or your steering rack has crapped out.
    If the TOP of the tires point in, then I'd start thinking struts and strut mounts.
    Trav
    skylin5_2 Guest
    it's the rear suspension that is sitting like that, the front is ok except it needs an alignment
    sxlostv1 New Member
    Los Angeles
    okay for rear suspension here's what's up.
    if it's your camber that's off, there's no real way to correct it except by getting a camber kit which in this case just be some eccentric bolts.
    If it's toe angle that's screwed up, go to an allignment shop and they'll fix it for you right there, unless your tierods are bad then you'll have to buy some replacements.
    js10coastr Guest
    have you modified your suspension at all? What kind of condition is your car in? The shocks could have gone bad (leak in the gas chamber) which would let the car sag more than it should, and then in turn screw up the camber/castor/toe.
