Engine performance clutch??
Discussion in 'Powertrain' started by cworkm, Jun 13, 2005.
    cworkm Guest
    Not only is my engine bad by my clutch is going.. will a performance clutch help in any way?? No serious mods and none in the future. Only Intake and exaust. also my corolla is a 01 corolla with a 03 engine soon to be in it.
    Also if it will help or just make for a better ride, what brands should i go with?
    Thanks for any help.
    sxlostv1 New Member
    Los Angeles
    i recommend Exedy. And also if you're gonna do a clutch job, You should change the flywheel too since it's right there. Those 2 things will help you out a bit.
    JDLangevin Guest
    If you aren't planning on doing any mods, then just get a stock one. It will hold just fine. And if the engine is going too, do them at the same time since you'll have to take them apart anyway.
    -Doc
    Mike4831 C-Town Pimp
    Statesboro, GA
    I upgraded to the lowest model as far as performance clutches go. I think it said that it gripped 40% better than stock. It was exactly what the car needed.
