Engine PCV Valve Replacement
Discussion in 'Powertrain' started by 93rollaracer, Jun 2, 2004.
    93rollaracer Guest
    just realized today that i just hit 25000 miles with my car today since i owned it, so its time for a new PCV valve. i've never replaced one before, so if anybody can give me some sort of idea of what needs to happen to get the new one in, i'd appreciate it
    d_samurai Guest
    got a 93? so its very easy-there's 2 hoses that go into your crankcase-the one on the right is the hose that has the pcv valve in it going into the crankcase-just yank it out-pull it out of the hose and slap a new one right in! and stick it back in the crankcase-i hope that helps-pictures would make it easy-go get a haynes manuel if your stumped.
    http://www.cardomain.com/member_pag...151_27_full.jpg
    just take a look-its in the middle
    HaPpYfAcE New Member
    Tucson, AZ
    you should prolly check/replace the grommet that the PCV valve goes into, as well...don't wanna be leakin oil if you can help it.
    turbo4age Love to Hate me
    NV
    d_samurai Guest
    oooh yeah...
    93rollaracer Guest
    cool...thanks
