Painting Wheels. Any tips?
Discussion in 'Exterior' started by jdmikey, Apr 5, 2007.
    jdmikey New Member
    Im about to spray my Integra mesh wheels black with a polished lip. Anyone out there have any useful tips? Is it necessary to use primer if im using dupli-color wheel paint?
    Shoot...i just realized this should have gone in suspension.
    nitrousoxide088 Guest
    curlupanddie420 Guest
    I had white konigs and stripped the whole thing with paint stripper. I should have used aircraft or wtv that stuff is called. I just tapped off the lip, primed it like 2 coats and then painted it 2-3 coats then clear coated it like 2-3 coats. I have to reclear coat it every here n there to get them shinyer
    Oh yea i just used regular spray paint like krylon n stuff. I didn't go all out with the project.
    midnightrolla Guest
    when i paint my rims and my frends rims i dnt use primer. i just used kyrlon paint. 4 coats ur good 2 go. not really professionally done, but it looks good
    TRDRider Guest
    listen man its all about your wallet...
    i dont paint profesinaly but i do a bid for my friend he as a tunner shop any way i painted two sets and all i can tell you is yes prime it make shure its all the same color (when its not primed you might have spots that arent the same) any way and then paint like you whould any thing else
    but here is the trick use a good clear a not cheap in a can one.... and clear it like 5-7 times i know it sounds like alot but wen you c the resolts youll be amazed
    it give it a wet look and also makes tem stronger cause you know your bound to have rocks hit them
    or you can always get them poweder coated but for that price just get a new set lol
