Engine Painting CAI
Discussion in 'Powertrain' started by jiggaman725, Jan 1, 2005.
    jiggaman725 the black guy
    Ellicott City, MD
    Painting CAI
    My girlfriend got me E.L Prototype's CAI for christmas and I waas thinking about sprucing up my engine a little bit by adding some paint. Just wondering if you guys have any idea how to paint the piping for the cai (i.e. do i need primer & clear coat? what type of paint? is this even a good idea?)
    all help is definitely appreciated.
    what color did she get you it in?
    statik New Member
    Well I haven't actually painted anything under the hood. But from what I've read in forums, and seen at the autoparts store it's no big deal. I've painted numerous other materials, so I can help with the basic concept...<br />
    <br />
    It's probably a good idea to use automotive high temp paint. Used for painting engine parts... I believe most of them are high gloss paint. So a clear coat probably isn't necessary. But if you want the extra protection from scratches, or want more depth, clear coat it. Not sure if there is a clear coat high temp paint. You would think so.<br />
    <br />
    Painting... <br />
    <br />
    You're biggest worries are:<br />
    Slick, incompatable surface. paint not sticking.<br />
    Oil<br />
    Dust<br />
    <br />
    Read the prep directions on the can of paint. You may need a primer... Primer just builds a base for the paint, and makes a smoother, stronger finish. If it's already painted you probably don't need a primer. just go ahead and scuff it up real good until you take the gloss off of it.<br />
    <br />
    Thoroughly scuff the surface. Use some steel wool or 150 grit sandpaper. The scuffed surface will allow the primer/paint to stick well. Wash with soap and water, dry. Just make sure you clean it well. Try not to touch the area that is going be painted.<br />
    <br />
    Get a coat hanger or two and make a hanger. Find a good place to paint. Hang it up.<br />
    <br />
    If you ever spraypainted you'll know to keep the can back about 12&quot;, take your time, make even strokes, and light coats. <br />
    Check with the directions on this, some paints dry faster than others, some will allow a second coat just 2 minutes after the first, some 15 or 30....<br />
    <br />
    If you want a deep gloss, get some buffing compound and buff it.. car wax should work... I would let the paint cure for at least a week just to be safe. I'm sure the high gloss will look great without buffing.<br />
    <br />
    Thats pretty much it. Nothing to it.<br />
    Hope that helps!
    Ellicott City, MD
    It's like a gunmetal color...I believe that's the only color you can get it in now. But I wanna paint it a nice bright blue.<br />
    <br />
    And thanks, Statik...I've painted a few things before, but I wasn't sure how exactly to go about painting this or even if I should paint it...I may just leave it how it is 'cause I really don't wanna mess it up.
    teevee247 Well-Known Member
    Montreal, QC
    If it is already painted, no need for primer. Scuff up the surface with a medium grit sandpaper so there is no shine anywheer. Clean it with a TSP cleaner (removes all residue, very cheap, like 2$ at a hardware store), rinse with water, let dry, apply multiple light coats of a high heat paint in the color of your choice. If you wish afterwards, you can use a high heat clearcoat to give it more shine/depth (and more protection from scratches too).
    alby13 New Member
    use high temp paint with or without primer and you will be fine.
