One speaker louder than the other
Discussion in 'Interior' started by rayray1, Jan 11, 2007.
    rayray1 Active Member
    I just replaced a set of defective speakers with some new ones and noticed that one is still louder than the other one.
    Then I reinstalled my stock speakers to make sure, same thing.
    The balance is set directly in the middle, it had no problems prior to installing aftermarket speakers.
    What could be the cause of this problem?
    a bad wire maybe? only thing I can think of
    How do I know which one it is?
    Will I have to replace all the speaker wiring in the door?
    DaCubanSkillz Active Member
    make sure all the plugs/wires are well connected. This happened to me once and it was a loose connection. also check to make sure the polarities are done correctly. make sure positive is with positive and negative is with negative.
    The polarity connections are correct as I double-checked to make sure.
    However, I'm not too sure about the wire.. I still have the stock wiring in place.
    Is it normal for the wire to go bad if its too old?
    maybe but it usually takes 15 years to do so
    but, if a wire got stretched it could have broken internally
    dward3 Well-Known Member
    Phoenix
    In my corolla, I noticed the balance was off too. Maybe I loss a few decibels in one side of my hearing. what kind of speakers did you end up buying anyways?
    I bought some 4" JL Audios for the front..... couldn't get anything bigger to fit
