Help! OMG - I need help with my projector PLZ
Discussion in 'Other DIY & Questions' started by KuroKuro, Feb 24, 2012.
    KuroKuro Active Member
    Vancouver BC
    01 Corolla Levin
    ok, trimmed the back of my housing and the inside bowl.
    and now i just fitted my projector inside and found that I can't hold my H1 bulb properly in place...
    also, i don't know how to make the back of the bulb water proof so that water won't to back in the projector. Thank guys.
    Do you have the wrong bulb size?... If your gonna try and make it water resistant try using some kind of silicone or sealer.
    Vancouver BC
    01 Corolla Levin
    Im pretty sure that this is a H1 bulb, so i can just use silicone is seal it off? and silicone is not gonna melt off right...
    Added: Feb 24, 2012 6:58 PM
    And the thing is I forgot to map out my original halogen cut off on the wall,
    so now i don't know where to align my cut off.
    Does any have the measurements of this? (like how far i should set my car and how high the beam should be and where should the cut off meet..) Thanks
    HIDplanet.com has all that info. Otherwise watch a tutorial on youtube.
    x2 you should do more reading before touching anything else on the car.
    Vancouver BC
    01 Corolla Levin
    ok, going back to HIDplanet to do some more research... thx for now,
    Did you figure this out? Sorry I wasn't here. I'm not entirely sure what the problem is, cause everything looks fine to me.
    Vancouver BC
    01 Corolla Levin
    I got the projector alignment and mounting all figured out now, and now i just have to reseal my headlight housing.
    However, after I disable my DRL and connect the HID, my front left yellow parking light stopped working, but it does blink when i use the left turn signal. I cant figure out why? >_<
    Must have cut the wrong wire yo
    Vancouver BC
    01 Corolla Levin
    oh sh*t really? I follow the guide on toyota nation, but my DRL did stop working thou...
    Maybe just the parking filament of the bulb is burned out. check by taking the working one and putting it into the bad bulb socket
    Probably just bad bulb like stated.
    Vancouver BC
    01 Corolla Levin
    ok got it, i will do them tmr morning, (so although the parking light and turning light use same bulb but there are two filament?)
    Yes. That's why when you have your headlights on, the corner lights are dim, then you hit the turn signal, and they flash brighter. Two filaments yo.
    Vancouver BC
    01 Corolla Levin
    oh ok, got it, thanks
    Sweet, you don't need my help :)
