ok need fellow computer geeks to help me
Discussion in 'Interior' started by moonshadow, Aug 19, 2003.
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    i finally got done building my PC and installed XP pro on there. everything runs good except the damn audio card. it is a Sound Blaster Live and eventhough the drivers are installed, it wont work. i already checked in safemode, regular mode and several other things but this damn thing wont work, no sound outta the headphone jacks, or speaker jacks, can ayone help or give me some ideas, i'm pretty burnt out and pissed.
    :x :x
    razz422 Guest
    Try going to http://www.soundblaster.com/ and search for your sound card’s model number and download the most current driver for XP. Re-installing the driver might help. It happened with my video card.
    oxymoron Guest
    Jersey City, NJ
    ok soundblasters site wont work on all 3 of my computers, and also there is an uninstalled multimedia component, but the blaster shows on the computer, could that be it. this is pissin me off.
    razz422 Guest
    Can you let me know the model number of you sound card? I’ll try seach for the most current driver and let you know the link (... if I find any :)).
    Jersey City, NJ
    Jersey City, NJ
    um, its just a regular sound blaster live 5.1 sound card, not the platinum or the othe one.
    Jersey City, NJ
    already have the latest drivers too. this is just buggin me now.
    razz422 Guest
    Ok, if you already have one, you should try re-installing it.
    It happened with my video card and scanner. I just had to re-install them.
    Jersey City, NJ
    already done that like 4 times
    Patsfan123 Guest
    Does your new motherboard have onboard audio, if it does you must disable it through the bios... If you come on AIM i can help you more, computers were my first love, now its cars :)
    razz422 Guest
    Wow, hardware expert!! :)
    I’m a programmer, but I know minimal about hardware :(
    Jersey City, NJ
    that is a good idea, i should try that, i never tried that. thanx, i'm on line at aim right now, my sn is stonetempel03, i would really appreciate your help cuz the mother board does have on board audio.
    yeye Guest
    I thought u work at office depot :p.... BTW mayb its defective?
    lostboy New Member
    yep that's what i was going to say ... you could also disable it through hardware devices ... and sometimes they have jumpers on the board to disable them ...
    what system did you make anyhow?
    computers are so cheap now .. i remember i payed $1000 for my amd 1100 tbird with abit kt7a and some ultra160 scsi drives and a geforce 2gts 3 years ago ... now i can get a 3.5 ghz for the same price with hella new good stuff ... too bad i don't need all that yet...waiting for new games to come out!
    xtm "Member"
    Panorama City, CA
    Could be an IRQ conflict. I would first try to relocate the card to another PCI slot and see what happens. You can also set the IRQ's in the BIOS to Auto.
    Have you disabled the onboard SND yet?
    I found out that 99% of the time, the videocard would cause an IRQ conflict with the sndcard, (most AGP ones)
    lostboy New Member
    I'm not completely sure about xp ... but w2k for sure uses one irq for almost everything ... it's like infinite irq ... so there shouldn't be a problem .. i think it's irq12 ... not sure ... anyhow .. did you check to see if the onboard card works.. if it's still working that is the problem for sure ...
    go to device manager and click on the sounds and see if there is a hardware conflict ...
    Jersey City, NJ
    what's that supposed to mean
    btw thanx guys, i worked it out, it was an issue with the card. i got a new one and it works fine. i also reinstalled windows cuz for some reason it was lagging the last time. hopefully things will stay smooth from here on.
    Pred Guest
    no offense but it probably wasn't the card, the older Sound Blaster Live! series sound cards do have problems with XP.. my 2 bro's, my dad, myself and some friends have this card, a sound blaster 5.1 xgamer(i have, others have reg.) and it just doesn't seem to work... you either can uninstall it from the hardware device manager/list and all its components then restart computer and it should work, if not just go into sound options and you gotta mess with your speaker settings, with what speakers you have... the creative drivers for this certain card or series of cards conflicts with XP, i do not reccommend installing the drivers as they are already in XP, just givin you a headsup :p
    Jersey City, NJ
    actually its working now. i got a new card, that one was defective cuz i tried it on my old PC with win 98 and 2000. it worked on both OS's
