OIl Light On
Discussion in 'Care & Maintenance' started by Machinehead2k5, Jan 19, 2011.
    Machinehead2k5 Chemosabe
    Atlanta/Augusta, GA
    99 Toyota Corolla
    I added oil because it looked like it was low, checked the dipstick. Drove around for a few hours and boom it's back on. I've done this method a couple of times. What could be the cause of the oil light coming back on?
    Thanks for the help!!
    Unplug your battery, wait a few minutes. itll reset the computer.
    No, no you need to get to the root of the problem. Unless you are burning that much oil, chances are that you may have a bad sensor. If this is the case, what I suggest doing is replacing the sensor. It may be a bit costly, but it will help you keep track of your oil consumption. Or, if you are immaculate about your oil changes, then simply take the bulb out of your dash and continue life the way it was.
    So... yeah, unplug your battery, wait a little, connect back and see if your problem is still there.
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    ^lmao. hummer u funni *asian accent*
    SaberJ2X Lurk MOAR
    Mayawest, PR
    usually that light only comes on when your engine is already seized up when it works anyways... lol
    I'd take the light off and measure the oil twice a month
    lol...so true. some guy brought his car into the dealership because his engine was having some problems. the mechanic started it up and it seized then his low oil light came on...LOL on a brand new lexus too....
    haha the love people give their cars !
    SaberJ2X Lurk MOAR
    Mayawest, PR
    can't blot/block out the sky with a finger :D
    if i was a mechanic i would of had a little joke in the chat like " hey did you notice the oil light on!, you should get it checked out"
    SaberJ2X Lurk MOAR
    Mayawest, PR
    client, the oil?
    you, no... the bulb
    Yess ! lol nothing better than that
    Rincon , Puerto Rico
    Means your oil pump is clogged or its not pumping enough pressure ... Soon your motor will blow [IMG]
    I think my oil pump might be going out...
    Atlanta/Augusta, GA
    The oil pressure was low, they replaced the pump. Came on for a couple of days after that. They said the bearings could be going bad, but add some STP to the engine and it should go away. Did that and no oil light since.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    a rebuild, it's calling you
