Oil brand?
Discussion in 'General Discussion' started by DaCubanSkillz, Dec 29, 2006.
    DaCubanSkillz Active Member
    Oil brand?
    What brand of Synthetic Oil do you guys suggest I use on the Camry. Which ones would you suggest I stay away from?
    And would a toyota filter be okay to use or would a different filter be better..if so, which one?
    ASG14 NooB, Kinda....
    Stamford, CT
    I only use Toyota filters with Mobile 1 Synthetic. Thats just me though.
    dward3 Well-Known Member
    Phoenix
    Kendall GT-1 (10W-30) . I'm clueless on the oil filter :D
    Denver Rolla 98 impreza
    mobile 1 synth, and a toyota filter... thats what I use...
    Des Plaines, IL
    Im with these guys. OEM Toyota Filter with Mobil1 Synthetic.
    Des Plaines, IL
    And now alot of other oil filter companies are basically fram filters just renamed. I know for a fact Penzoil filters are fram filters with a different name. I just stick with OEM toyota as those are cheaper for me.
    same here
    Stamford, CT
    ^ I think its not just me, but everyone now, haha. WalMart gas 5Q jugs for $22.**.
    Des Plaines, IL
    Damn straight lol. Walmart, only place to get your Mobil1 lol.
    01rollas New Member
    AMSOIL 20W30 turbo formulated , Royal Purple 10W30 Synthetic , and Mobil 1 Synthetic 20w30, except the Hybrid uses Honda Brand Only due to extremely low viscoxity status 0w20, All vehicles use Hastings Oil Filter provided in by AMSOIL.
    toyota filters and mobil1 here too. big surprise. 10w30 for me.
    rayray1 Active Member
    seems like I'm the only one here who's still using dino oil
    Castrol GTX 5W30 w/ Toyota Filters.... sometimes FRAM if I can't find anything else on hand.
    EDIT: I currently have 84,000 miles on my car... is it too late to switch to synthetic?
    D Matrix Member
    Cleveland Ohio
    Castrol Syntec with a Fram filter for me.
    JLee TD05 3SGTE
    NH
    I use whatever I happen to have bought last..I've used Mobil1, Castrol GTX, Supertech..and probably others.
    Is there any scientific basis for not using any particular brand of oil -- ie is Supertech (Walmart) actually any different than Castrol..Valvoline..etc?
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    *edit* posted in wrong thread. */edit*
    cgreen38 Common sense, p
    Baton Rouge, LA
    I use dino oil, too. Castrol GTX 5w30 during winter and 10w30 during summer. I always use K&N Gold Oil filters.
    Can't go wrong with Mobil1 and OEM filter - worked for me on two cars - both over 100K miles on a 7500-12K mile drain interval. Started on the Matrix that we bought with 40K miles on dino - now with almost 60K and synthetic - mileage has improved quite a bit.
    Also depends on your drain interval - if you are aiming to change your oil every 3K miles - then conventional motor oil should be plenty fine. In fact - some conventional motor oils can be very close to some Group III synthetic oils, specification wise. Just have to make sure the oil meets the new API standard class - SM grade. There is still quite a bit of oil that is old and sitting on the shelf.
    Others that I've used with good luck - Pennzoil Platinum (sometimes runs as low as $2 a quart with a coupon), Castrol (GTX, Syntec Blend, Syntec), Valvoline (All-Climate, DuraBlend, Synpower), SuperTech synthetic (Wal*Mart), Amsoil, Mobil (5000, 7500, M1, M1 EP), Royal Purple, Red Line, and Shell Rotella/Mobil Delvac.
    Filters used are Toyota OEM, Purolator, Purolator PureONE, WIX, NAPA gold, K&N, and Mobil. Never had any problem with any of them - only have problems with FRAM (one regular and one DuraGuard - filters collapsed internally, and one SuperTech brand - also collapsed internally.)
    Right now - I get the best deal on Toyota OEM filters of all things - $3.50 each when you get a case pack of 10 filters + a couple of free gaskets.
    igorien2k New Member
    how good is hastings supposed to be? Ive been using bosch and i have to drive 20 minutes just to get them and its a pain in the a**.
    Hastings is a pretty good filter - I'm surprised that you can find a Hastings filter easier than some others. I think the manufacturer of Hastings filter is AMS - a big maker of motorcycle filters.
    asn13oy Stepping Stones
    OC, CA
    Amsoil 0W30 or 5W30 (right now it's 10W30 b/c autobacs was out of 0W and 5W =D) and, of course, Toyota OIl Filters. I usually change every 4-5000miles.
    gotarheels03 New Member
    Toyota filters seem to be really well made. Obviously I dont have a Toyota anymore, but Mobil 1 and Toyota filters are all I use on my Mom's Solara. Ok, well I do top it off with dino sometimes.
    alby13 New Member
    i use K&N filter with Castrol Synthetic.
    I use Mobil1 Synthetic 5W-30 w/ a toyota filter like many others :D
    My car was switched to synthetic at 1000 miles, as is now I have 57K and burn less than 1/8 quart per 3000
