NTK 00celica bucket seats WIF 00corolla bolt patterns?
Discussion in 'Interior' started by YangkuuzaCreations, Dec 20, 2006.
    YangkuuzaCreations Guest
    hi everyone i was wondering if the stock celica bucket seat will fit onto my 2001 corolla s because i want to have buckets but i want it to look as close to stock and i was juss wondering so if any1 knows and it does then i need to find a pair of black oem celica bucket seats for my corolla please hit me back a tell some1.
    Yes it fit, but as falnfenix said, it won't directly bolt on. You need to mod it to fit.
    yep. the EASIEST answer is to get a custom set of brackets made, unless you know how to weld...then destroy your current seats in the process of removing said brackets, and weld your corolla brackets to the celica seats.
    if you choose that route, make sure you measure QUITE A BIT before welding.
    I usually say this but check your local Junk Yard first. Then look up ebay.. sometimes you'll get lucky and you can get those stuff for mad cheap. Junkyard is my friend. lol. I dont know if you can just do a seat swap. Well seeing that both are toyota, i'm sure you can. but I think if you do it, your bucket seat will be raised a bit higher than what it is on the celica.
    no, they won't bolt right in.
    o i c ok thnx guys i was juss wondering i might prolly juss go with the recaros then instead lol thats too much of a hassel so ill get recaro from friendsw shop its only $250 for both and it matches the interior as well its black with red stitching^^ thnx for everything guys^^.
