Engine Nitrous
Discussion in 'Powertrain' started by bewildered_spruce, Mar 11, 2004.
    bewildered_spruce Guest
    Nitrous
    I've been thinkin about hooking up some dry nitrous to my rolla since it's a lot cheaper than FI and i was wondering if anybody's dabbled with the giggle juice with their rolla. I'm thinkin that the 1ZZ could take a 30 shot no problem but i just wanna make sure.
    Thanks
    RexPelagi VDub
    Canton, Ohio.
    IDK honestly Id be worried about it. But I think you should be alright with 30 shot. I think. Im not really 100% sure as to what the numbers mean.
    crovax New Member
    supposidly...the injectors are good for 120 at the wheels running at 75% max, so figure about another 30 hp before the injectors are maxed out.
    methaneb Guest
    Run Premium fuel if you decide to go for it.
    Tro1086 Guest
    So wouldnt that mean that the injectors would need to be replaced after you got the supercharger? Or am in interperting it wrong? Isnt it bad to run the injectors hard thou?
    Say pushin 200 HP, like a SC and TRD CAI and exhaust, with header, that would give you enough power to require new injectors wouldnt it?
    oddfish Guest
    If someone knows the flow rate in lb/hrs for the injectors then it would be easy to tell the max horsepower the injectors could theoretically support. The few people I have asked have said not to run injectors more than 80% full time, not sure about that though
    RollaS New Member
    the supercharger includes a 5th injector
    Tro1086 Guest
    Oh ya, forgot about that part
