New Whitesonic Headlights
Discussion in 'Exterior' started by FasteddieTRD, Sep 21, 2003.
    FasteddieTRD Guest
    I just ordered Raybrig 9006 Whitesonic headlights for my Corolla and I was wondering the best way to install them. Can I just take the headlight cover off or do I need to unscrew like 8 different things and take my wheel off?
    http://www.cardomain.com/id/eddie782
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    are those bulbs or actual head lamp houing cuz for bulbs nothing needs to get unscrewed.
    FasteddieTRD Guest
    bulb
    yeah it's just the actual bulb itself. ok so I just pry the cover off of the light and screw the new one in? ok cool
    Jersey City, NJ
    yeah disconnect the harness and then twis the bulb and pull out
    that should help you change it real easy.
    FasteddieTRD Guest
    bulb
    i noticed that the headlight cover itself is on there pretty good and there are some plastic pieces that slightly cover the top of them, do i just pull them up and back with something? or have u done it differently? thanks
    Jersey City, NJ
    dude i did Silverstars and then my HID's and all i did was take off the harness, grab the bulb and turn it to the sid, that makes it free the grooves so you can just pull it straight out, there is no cover there, i think what you are refering to is the intake tube curling up right there.
    ph0bi4 Guest
    Thats all i did with my turn signal bulbs. Twist, remove, replace. the end.
    methaneb Guest
    Re: bulb
    You don't take the cover off of the headlights. Behind the headlamps (under the hood) you will see the wiring harness for the bulbs, twist the base of the bulb and it will come right out. You may need to pull out the battery to get to the driver side ones.
    [TRD]Rolla Guest
    TWIST IS THE KEY!
