New floor bar installed
Discussion in 'Stop, Drop & Roll' started by sxlostv1, May 8, 2005.
    sxlostv1 New Member
    Los Angeles
    I just got my floor bar in on friday and I want to share with you all how it came out. I got it from ebay (just look under "floor bar"). It costed me 46 dollars and it is extremely heavy duty. I've seen rollcages with the same thickness of 1 1/2 inches thick. Took me about 30 minutes to install and when I drove the car around, I noticed that it felt less flexy than it used to. well here you go guys.
    Shifty SIdeways Noob
    Memphis,TN
    Where does it mount to?
    sxlostv1 New Member
    Los Angeles
    mounts to seatbelt bolt. i believe the back end is supposed to be bolted on to the chassis but i havent had time to drill holes. maybe i'll do it some other time.
    Do you have your rear seats permanently removed or are you putting them back in?
    sxlostv1 New Member
    Los Angeles
    for daily driving, i have seats out. but if i ever need to drive people, i can pop the seats back in. ive tried sitting in it with seats in and the bar in, theres no real burden in the legroom.
    BangRolla New Member
    houston, texas
    yeah it looks pretty flush to the seats.
    SlowRolla97 New Member
    Was it made for your year or did you get one for a diff. gen? I would like to get one, only if they do really make a difference. I have a 97 though, so if I get one for a diff. gen is there anything to adjust it so I can make it fit?
    sxlostv1 New Member
    Los Angeles
    i found it on ebay and well here's the description of the product.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    ASMI seems reputable. I've gotten some parts from them in the past without any problems.
    Put enough of those bars in, and you can do a convertable conversion! :D :D
