Forced Induction New eManage Map for 01 Corolla
Discussion in 'Powertrain' started by Barnacules, Dec 22, 2005.
    Barnacules 100101101011011
    Duvall, WA
    I've got my 01' Corolla completely installed and my eManage and S-AVCR installed. My only problem now is I don't have a map for my turbo to upload into the eManage because the one I used from a 98 Corolla without MAF sensor does not work at all, it just makes my car die. If anyone has a 01+ Turbo'd car would you please let me try your eManage map to see if it works? I just need something that will allow me to get the car to a Dyno for final tuning but the map needs to provide enough gas to prevent engine knock until I get to the dyno.
    Duvall, WA
    Bump...
    I've got the car running okay but its way to rich. I'm looking for an emanage map for an 01 or 02 corolla that is tuned for 550cc injectors or stock injectors and I'll use the ratio to change them. All the maps I have tried do not work for my car. that is from the 98 corolla that is non VVT-i and does not have the MAF.
    hmmm --- see here's the issue with that Jerry... the map i gave you doesn't use *ANY* of the airflow sensor tricks... i did this to avoid having any issues with that EXACT issue across platforms. however, once you upload it into your eManage you *HAVE* to tweak the settings to make sure that the injector correction is 100% right and all the correct maps are selected in the parameters section. I used the same map on a Celica (which happens to be EXACTLY the same wiring/motor/trans config as your rolla)
    Duvall, WA
    Wierd man. I loaded your map and did the 550cc injector convertion in the emanage software fomr (260 to 550) and the car won't even stay running and just chugs like its running super super rich. But when I load this Celica GT map I found on google it works fine except for it has cold idle problems. I'll give you map another go tonight and see what happens.
    Thanks man...
    np, sometimes the map can be a little wierd... you do have *ALL* the updates in place don't you? :)
