Engine new bearings in the motor or say screw it
Discussion in 'Powertrain' started by Dreadon, Mar 18, 2008.
    Dreadon Guest
    so here is my delema i can get the bearings replacedin the bottom end if that is the problem for around 700 and a remand or used motor is out of the question. it would cost more to replace the motor than the car is acually worth which is gay if you ask me and now idk what to do im gonna run some thicker oil in it for the time being but then idk how long its going to last me. im really mad about this
    anyone have any suggestions
    las vegas
    year of car?since you said used motor is out of the question your only route is buying a new bearing or rebuild the whole motor and i wouldnt drive the car you just gonna make things worse.
    las vegas
    from what i know,nobody on this forum had done it knowing toyota dealer they like to rip off consumer so im guessing $700 is expensive.
    rolla996 Guest
    yea thats what i was thinking. I figured i was misreading it at first and seeing it as 700 for the dealers parts and then another amount for labor.
    And i am unfamiliar with which bearings too. The ones that control the pistons? IDK if it is the engine's bearings, but it sounds mighty complicated.
    Don't quote me though, i may be wrong.
    Dreadon Guest
    its an 01 and with 107k on it and i know i should drive it i just put some thicker oil in it to try and prolong the effect but i will have to drive it come next week cause spring break is over.
    also has anyone had to change the bearings out is it easy to do toyota wants 700 w/labor to do it
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    If I were you, I would go with replacing the bearings just because you never know what you could get buying a junkyard motor or a used one. At least you know how the motor you have now has been treated. You never know the last motor could have been beaten worse than the one you have now and die 10 miles down the road. Just my opinion.
    Dreadon Guest
    yah the rod bearings is what im talking about we know most of the people who work at toyota and he said around 700 with labor i mean it maybe around there but yes you are right it is a very complicated job and that seems to be the only option i have right now
    rolla996 Guest
    might as well as do it if u have the money. To hard to sell and not expensive enough to have to buy a new car.
    Just pray nothing else will go bad afterwards = )
