need to remove bumper for Halo install?
Discussion in 'Exterior' started by rubybum, Aug 11, 2004.
    rubybum Guest
    i just finished installing M3 lights on my car. next i want halo head lights. but, will i have to take off the bumper of the car? lifting the hood it doesn't look like i have to, anyone know for sure?
    GT-R Guest
    You don't have to remove them all, but you might as well for easier access. Just look in the diy section of clearing the headlights and it should tell you what bolts you need to remove, good luck.
    Corollaized Guest
    I believe you will have to remove your bumper.
    I was attempting to remove my headlights yesterday to look for my foglight harness. There are two bolts on the top of the headlight and one on the side right under the bumper cover. You might be able to get a 10mm wrench in there but I dont know if there is enough clearance between the headlight housing bolt and the back of the bumper.
    Good luck
    polo708 New Member
    9thgencorolla.com
    you need a ratchet and you have to pull the bumper away from the car. It will feel like its going to break but it wont.
    Definately easier to just take the bumper off if your doing both lights.
