Need Real Advice!!
Discussion in 'Stop, Drop & Roll' started by DrunkSaru, Dec 19, 2007.
    get it fixed right away.
    rolla996 Guest
    Need Real Advice!!
    I did my tire rotation today, and when putting bolts back on, one of them would no longer fit its designated spot. I tried oiling them but it seemed like it was the actual part (not the bolt) that was now refusing to have the bolt screw back on.
    When i got started on the other side, i had the same problem only it was tightening effort, It eventually snapped. The lug with the nut snapped. So i only have 3 LUGGS now. I have no idea how much it will cost and i am on such a tight budget. U think its safe driving with it like that for a while. It makes no noise and is rather smooth. No wobbling.
    Both rear wheels now have only 3 bolts holding them in place, each is securely fastened though. Holding the wheel in place.
    DOT. Noypi ako!
    Wheel studs? Replace them. It only cost less than $2 at Autozone, Kragen, Pepboys.
    rolla996 Guest
    omg txs so much, i was under the impression i would have to change so much more.
    no, but you'll need a new set of lugs if the stud broke off inside the nut
