Engine need new clutch assembly
Discussion in 'Powertrain' started by gridjockey, Oct 1, 2006.
    gridjockey Well-Known Member
    glendora,ca
    any recommendations for new clutch , nothing fancy but something more durable than the baseline corolla setup.i have a xrs with 21000 miles and the clutch is slippin. i bled the slave and found a little air but nothing signifigant. it also is starting to smell like it's burning. what a pos . i normally get anywhere from 60 to 80 thousand miles on a older celica. my wife drives it and her shift points are ussually around 4000 rpm and she never rides the clutch. i drive it once a week to experience the lift.i hit it hard but only to open it up. i have a toss up between exedy , fidanza , trd, centerforce, clutch master, and a couple of remanufactured oem outfits.looking for nothing more than a stage one setup. ive ordered a longer rod for the slave unit.
    cgreen38 Common sense, p
    Baton Rouge, LA
    I'd go with a fidanza. When I replace the clutch and flywheel in my car, I'm going with fidanza for both.
    imported_punkbrad Guest
    this SUX. my clutch just crapped out, and just like all the other hundreds of people, the dealer says nothign but "its not covered under warranty". SO i think I am going with the stage 1 Exedy clutch. Anyone have any input or feedback on the Exedy clutch?
