Engine NEED HELP
Discussion in 'Powertrain' started by bxman89, Oct 24, 2012.
    bxman89 Well-Known Member
    So I swap a new motor in my 8th gen, pouted everything in, add all fluid and then when I put my key in and crank its turn on over then dies. Please lmk asap.
    I just looked at your thread, and based on a pics, seems like you swapped a vvti motor in your non vvti car.
    No its a 1zz non vvti
    that definitely looks like a vvti motor based on the valve cover. You can see the holes from the the coil will be bolted down. Also you see the holes for where the plastic cover would bolt to the valve cover, and lastly the vvti motors had the oil cap hole raised like that. I could be wrong, but im going off what i see.
    Does it have GAS ?
    yes it has gas lol alot of peeps i talked to said it could be my timing chain/???
    Did you get it fixed?
    not yet btw dnt know how anyone wanna help do my timing chain will pay u..
    Mack? Lol.
    im for real
    Mack does need money....
    I need money too...
    Gold asks; How much?
    Me say: HEHEHEHEHHEHE :)
    I've never done it but it should be covered in the Haynes manual.
    Just because the Haynes manual shows you how it's done dosent mean your capable of doing it.
    Which is why he needs to actually look in the manual, and see if it's within his capabilities. He had help switching out an entire engine... I think he can find resources for a timing chain.
    Fuck you gold.
    He says for post number 10101
    How much?
    Over 9000 dollars!
    Whaaaaaaaaaa?
    I'm not giving you over $9,000 haha
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    Is the MAP sensor plugged in?
    Would that prevent the car from starting?
    No, it would cause a CEL and not accelerate past a specific RPM, in a 5 spd anyways. Not sure how it would affect an AT.
    Yeah it's some intake thing I thought
    Still need help? :troll:
    naw car running
    Any other updates?
