Engine NEed helP!!!!!!!
Discussion in 'Powertrain' started by jtweezy, Jun 22, 2005.
    jtweezy New Member
    Irving, TX
    NEed helP!!!!!!!
    hey my moms 94 corolla won't start.....when i turn the key it just makes a continuous clicking noise and i see the belt move a little.......Plus i already changed the starter......and then it turns out that the starter is still good....and i also checked the alternator.....and its good too......so now i don't know what else to check....Please HELp!!!!!!!!1
    AE102 New Member
    i was gonna say starter, but then you saids its fine. dunno, thats how my '96 was, just click and click.
    BangRolla New Member
    houston, texas
    have you tried the battery?
    statik New Member
    Check the battery cables. Starter connections and cables. Seems like it's trying to turn but not getting enough juice. If you know the starter is working properly then somewhere along the line the current isn't getting throught like it should.
    SlowRolla97 New Member
    When my car did the same thing it was the starter, but you said this isnt the case. When my girlfriend car did it, it was the ignition switch. You might wanna check the fuel pump too.
    JLee TD05 3SGTE
    NH
    You may want to try cleaning the battery terminals..a friend of ours was borrowing some guy's (beat) Ford Ranger..it had been starting all day, then wouldn't. The terminals looked perfectly fine (no corrosion or anything)..but he called the owner (an aircraft mechanic) and he said to clean the terminals. I didn't think it would work, but it did..
    Cape Coral, FLorida
    go to walmart, they sell a battery installation kit for like 4 bux, it comes with terminal cleaner and that brush thing
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    battery, spark plugs/spark plug wires OR distributor other than that I dk what to tell u...
    JLee TD05 3SGTE
    NH
    If it's a manual, will it push-start?
    milhousse C U in the car
    Winnipeg, MB, Canada
    I am going to say with almost 100% certainty that you have a power issue to the starter. I have had this happen in my sister's neon once and one time in the corolla. Check your terminals and clean them, even if they look clean. Check the wires going to your starter. When it happened on my sis's neon, it turned out that the power wire was ran incorrectly when repaired once and basically melted through part of the battery casing and itself.
    statik New Member
    If it's not anything in the ignition system then it may be the fuel pump. Thats all you need to start is a spark and fuel.
    01rollas New Member
    I have no idea about your mom's car.
    yea thats something i should have mentioned, considering it happened to me last week. check the fuel pump, the gas (not the gauge, just tap the tank!). Check the fuel pressure (with a gauge or... just loosen off the incoming line and turn the key very briefly... then let the gas dry up if it came out, thats the easy way to check if you have ANY pressure.)
    jtweezy New Member
    Irving, TX
    ok guys............well after putting the old starte back on ......i changed the terminals and wires and also got my mami...a new battery....and its works fine now......so thanks for all the input....1
    good to hear.
    if i ever have problems with starting, the first i check is fuel then the battery.
    Littleton, CO.
    sweet stuff man good thing u got it worked out :cool:
    AE102 New Member
    yep, good to hear. and dont freak out when you 1st try it. it'll work out aight in the end.
    statik New Member
