Need Help!?!?!?!?!?
Discussion in 'Exterior' started by 2006vvti, Jun 16, 2006.
    2006vvti Guest
    Need Help!?!?!?!?!?
    I CaN Not Find Any 2006 Performance Parts For My Rolla. Can I Buy 04-05 Parts?????????????? I Have Called Every Place That I Know Of, They Can't Tell If They Will Or Not!!
    Weezer Guest
    They are exactly the same car so any parts from 2003 & up should fit. If you have an XRS, then they may not have many parts for it since it's still fairly new. However, engine wise, Celica GTS parts should work (since it's the same motor detuned from 180hp to 165hp).
    The 2003 & 2004 Corollas have a larger throttle body than pre 03 & +05 (that's why they have 130hp instead of the 126hp from 2005 & up).
    Other than the throttle body, everything else is the same. You won't find much performance parts for Corollas since they are rarely modified by their drivers.
    This one is wrong. It's not like it has a larger tb or what. 03-04 is drive by cable, 04+ is drive by wire. Their HP are the same, they just change the HP rating since 2005.
    Weezer Guest
    Doh! My bad. I still prefer the cable tho, call me crazy.
    126 & 130 are not the same numbers. Perhaps I should put on my glasses.
    It's not that noticeable behind the wheel, tho my 04 can slightly edge out my friend's 06 "S" model. Both 5speeds. I have larger wheels than he does, yet I still manage to leave a couple of feet between him and I when we drive side by side.
    No, what I mean is the *real hp is the same, just the numbers (126, 130) are different since they added the SAE in 2005.
