Engine Need help!!
Discussion in 'Powertrain' started by Speedracer41, May 4, 2005.
    Speedracer41 Guest
    Need help!!
    Well......My MIL came on today, P0420 cat sys below eff. Well this will be the third time I have put a ct on it. Has anyone else had problems with this? Any suggestions?
    CorollaULEV Guest
    Something isn't running right. Make SURE that sub-O2 sensor is working okay. Running rich will burn a cat up in no time, as will running lean. You've got a mixture problem. What mods do you have?
    Trav
    Speedracer41 Guest
    Injen CAI, Magnaflow muffler - Thats it, thats why I don't understand why the cat is failing, A CAI should not cause it to run lean.
