Engine Need help solving problem
Discussion in 'Powertrain' started by Dreadon, Aug 3, 2007.
    Dreadon Guest
    Ok so here is my dilemma ive had the car for just about a year now its and 01 corolla 4spd auto and with 96k on it the tranny is not right and now i cant even rev the engine while in gear wtf it shutters like it is going to stall. at first i thought it was the tranny but now idk then engine was shuttering in park so idk. i had to travel back home tonight and almost didnt make it. it was so hard to keep 60mph and then when i got home i could barely go 30. it happens in all gears even in 4th and with overdrive off, idk what to do any ideas. its late now so i cant check any ideas would be nice ill look at it 2morrow moring
    jcrwzr Member
    Simi Valley, CA
    have you kept up with the maintenance? what are your driving habits? i'm guessing you're the second owner of your 01 corolla. please give us more details.
    Dreadon Guest
    ok so my neighbor came over and he says it is misfiring but doesnt know which one so i need to get a scanner and check which one. then it with either be a coil pack or the plug but in the end i have to spend money. and i also agree the dealers are all assholes they dont care about you or the car they just want the money i know my dad used to work for one. why must things brake on the worst day ever.
    If its a bad coil pack, you can get one at the yard.
    It has nothing to do with the transmission. Seems to me that you have 1 or more dead cylinders. This is what it causing all the shaking. Combustion is only occurring in some cylinders and so throws the balance off dramatically. Check the direct on coil packs and make sure the wiring is all intact. Check your spark plugs to see it any of them are damaged. I seriously doubt this is the problem but also check all your vacuum lines and hoses. I would recommend you bring the car to a mechanic and have him do a compression test. The problem could also be due to fried rings that aren't doing their job anymore. The mechanic can take it from there. And I do agree with jcrwzr. What is your driving style like?
    interesting.. i would also agree with checking compression. I would go to a mechanic you trust though. Not a big fan of the dealership
    Dreadon Guest
    thanks for the help ive kept up with the maintenance help i just put in royal purple 5w30 in the engine and their atf for the tranny 1500miles ago. last night when i came home the check engine light would flash on for 10 sec then go off i really hope the engine isnt shot. but the funny part is yesterday i went to emissions here in ct and it passed. it was acting up 2 days before that but it didnt do it while i was there so idk. it has only gotten worse from there so now im worried. well my driving style is a little mixed im kind of hard on it 3-4k when shifting sometimes 5 when getting on highway but only when i really need to but i also drive like and old person at night when im tired so i would say mixed and im actually the 3rd owner of the car 1st was a lease 2nd lease too and now i bought but carfax says it was maintained at the dealership all its life so. but also the last owner was an old person so that may have something to do with the tranny problem but the engine stuff is new
    jcrwzr Member
    Simi Valley, CA
    rent/buy an OBD2 scanning tool from your local autoparts store. is there an Autozone in CT? they loan OBD tools. When the engine check light turns on, pull the code. If I remember correctly a flashing CEL (check engine light) has something to do with either system too lean, timing, spark, or vacumm.
    you also mentioned that it's been through 2 leases. I have friends who lease and they treat their cars like crap. So when dealerships talk about their pre-owned vehicle sales (trade ins or leases), I take it with a grain of salt. Because... what's the bottom line? MONEY!! Of course the dealership will tell carfax that the car has been kept in shape!
    Anyway, my auto mechanical knowledge only goes so far, if I were you, I'd take it to a trusted mechanic. If you're the weekend warrior, get the OBD2 scanning tool and find out why the CEL or MIL (Malfunction Indicator Light) is turning on.
    Bring it to a mechanic ASAP. The problem could get worse. Remember to do a compression test.
    Dreadon Guest
    so i took the plugs out and the are ok i moved them around to see if that is it. my neighbor who is an mechanic is coming over to check it out. it stalls on the low end when in gear but revs fine when in park or neutral. he doesnt have a scanner so i may need to find one yah i know autozone does it but i dont have the time or money today to rent one.
    Dreadon Guest
    i was going to get a new one but should i do that instead
    Dreadon Guest
    ok so i solved the problem too most of day i went to autozone and rented a scanner went though and read codes came up with misfire cyclander 3 and 4 so cleared then let go again took a little while and drive around but kicked off misfire in 4 ok so now i moved the coils around 3 into 4 and vice versa cleared and came up still with 4 so it isnt the coil took out plug in 4 moved to 3 and cleared drove around check engine light came on this time and was now in 3 so figured out it was a plug. and went and got denso iridiums plugs for it and replaced all of them and no more problem. things i learned today dont get crap spark plugs use original ones in engine and also Autozone can not clear any codes on ur engine if you go there some 10k fine if they do but you can rent a scanner for 150 and use it and bring it back when your done. so it was a fun day and thanks all for the help with trying to solve problems i just hope the problem doesnt get any worse after this hole ordeal
    jcrwzr Member
    Simi Valley, CA
    wow.... that's all i have to say....
    OMG wow!!!
    Dreadon Guest
    sorry
    lol figured id tell you since u all helped. thanks again sorry for the long explanation thanks for the ideas i wouldnt of guessed it be the coils and thank god it wasnt again sorry and thanks for the help
    No problem man. What were the condition of the plugs?
