need HELP HELP
Discussion in 'Stop, Drop & Roll' started by bxman89, Apr 15, 2012.
    bxman89 Well-Known Member
    when i make a left turn my right rear make a sratch nosie does that me my tires are to big or i need spacer????
    What are your wheel specs? Lowered at all?
    no not lower at all and rims specs are
    size 15 x 6.5 bolt pattern 4 x 100 offset +40
    what tire size? You shouldn't be rubbing with 15s though.
    i will post tomorrow to dark outside
    I think you are hearing a bad bearing dude.
    Or your shocks are blown
    CorollaGT likes this.
    Either your struts are blown, causing the car to lean excessively during cornering, or your wheel bearings are shot. Do a very slow left turn in an empty parking lot (slow enough so the car doesn't lean) and see if it still does it.
    no only when turn hard/ fast or if i have something heavy in my trunk n hit a bump then it make that noise.
    Time for teins + kybs.
    coilovers.
    We've talked about this and it always comes down to cut springs and kybs.
    cue the conversation about Corolla owners being cheap....
    cue CCC coming in here to talk about HP and how their cars are faster than ours!!
    Cue golds comment about corolla owners being cheap and boasting superiority by driving a lexus.
    Oh wait... already did.
    No buddy, that was your comment about corolla owners being cheap lol.
    You started it,
    I didnt mention cheap anywhere in this thread.
    yes, but you started "the conversation about Corolla owners being cheap" back in your side skirt thread lol.
    Wow wow wow, player hater. Why you yanking my chain about that thread? That was like a millenium ago.
    yeah never mind... we really aren't being too much "HELP HELP" are we haha
    HummerH2O likes this.
    i just bought my tein s spring today and my window visor. then in a few weeks buying my struts. bte my tires in the back are 205 50r
    Are you going to install the shocks and springs together, or do all the work twice?
    im buy some stock sturts and doing it all at once also ill be buy my rear window visor to : ]
    why you buy stock struts?
    on a budget right now
    Ah, so you're assuming your current shocks are blown. Well, if you had saved a little more, you could have gotten better shocks! Then you would have saved money in the long run, since better shocks will last longer.
    yea true but ill be buying orally struts
