Need help for stock steering wheel removal
Discussion in 'Interior' started by stiff, Apr 6, 2005.
    stiff Guest
    Just got a momo steering wheel and the hub adaptor not too long ago. i was trying to install but couldnt figure it out. i was wondering if anyone out there knows how to remove the damn steering wheel. i already got the airbag off now i just need the steering wheel off.
    thanks
    srt4me Guest
    There should be a bolt rite in the middle. Undo that bolt and pull for side to side. Be careful not to rip the airbag component as you pull, not that you'll need it. Thats all I can remember rite now. If you still can't get it, maybe you should come up to LA during the weekend.
    Tamago New Member
    i know how to fix the signal thing.. you'll need to slightly modify your momo hub adaptor.
    stiff Guest
    oh thanks for the info i finally figured out how to get it off on the way to kragen when i was at a stop light so had to put it back on really quick and went back home. i might need some help for the wiring for the horn and also once i put the momo on my turning signals dont automatically turn off anymore after each turn. i have to see if thres a way i can fix that. momo looks awesome. thanks anyways for your help.
    stiff Guest
    oh really if theres a way you can explain it to me that would be really cool. im going to see if i can try to do it my self but i dont know how to start it off. i also need to connect the horn to it. thanks
    Tamago New Member
    horn is an easy one.. i used a phonecord as my transmitter wire for the horn.. it coils up nicely and extend/retracts as you turn the wheel.
    if you look at the stock steering wheel you will see a small notch in the face of where the wheel goes onto the spline.. you must duplicate that slot on your new hub and your signals will work..
    Phozenstone New Member
    question...if the wheel is misaligned, such as when ur going straight, the top of the steering wheel is to the left..all i have to do is unscrew the giant bolt in the middle and realign the hub right?
    stiff Guest
    Correct i had to do this because my wheels werent straight when i installed the momo
