my rear speakers dont work!!! help!!
Discussion in 'Interior' started by istylez, 2003年03月09日.
    istylez Guest
    i need help!!!!!!
    i currently have a pioneer deh 6400 as my HU and using the stock interior speakers. and have added 2 12" JL audio w6.
    On my deck I can either control FRNTS + S/W .. OR FRNTS + REAR. But if i choose FRNTS + READ. i can't control my subs on my deck. but all my interior speakers work. if i choose FRNTS + S/W I can control my subs onmy deck but[/b] my rear speakers no longer work!
    how do i fix this?!?!?!? I need help!!!! How do i get all of my interior speakers to work AND be able to control my subs. Thanks!
    oxymoron Guest
    More information needed I'm afraid. What amplifier are you using for the subs? How have you connected up the system? I can't find any info on the deh 6400 on the web - it's not a current model.
    istylez Guest
    yea 6400 is the 2002 model.
    ok. my HU powers all my interior speakers.. thats. 2 tweets, 2 fronts, and 2 rears and then my amp powers my 2 subs.
    sipmle as that
    oxymoron Guest
    How is the amp hooked up?
    istylez Guest
    what do u mean, how? rca and remote to deck. power to battery, ground to some metal thing in my trunk, and speaker cables to my subs. nothing special.
    my amp is solely for my subs. not for any interior speakers
    oxymoron Guest
    When you select Front + S/W as your output control, are you sure there's nothing coming out of your rear speakers? Try disconnecting your subs and listen very closely. I'll bet that your rear speakers are getting the sub output only.
    stratus Guest
    NO NO NO NO NO, I have heard of this before. I am sory that I cant be much help but this is a common issue with that deck. I forget how you fix this problem. All I remember is that you have to go through the menu on the deck and choose a different setting for the sub output. Read the instruction manuel, it is in there. It has nothing to do with the way that it is wired.
